Ga door naar hoofdinhoud
Razer Barracuda X Battery Replacement
Wat je nodig hebt
  1. Razer Barracuda X Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Razer Barracuda X Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Razer Barracuda X Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the cushion by pulling it off from the edge and out from the grooves.
    • Continue to pull the cushion away from the speaker until the cushion is fully separated.
  2. Razer Barracuda X Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 6 mm Phillips #1 screws from the left side of the speaker casing.
  3. Razer Barracuda X Battery Replacement: stap 3, afbeelding 1 van 2 Razer Barracuda X Battery Replacement: stap 3, afbeelding 2 van 2
    • Gently pull the speaker casing away from the shell.
    • Place it face down to access the battery.
  4. Razer Barracuda X Battery Replacement: stap 4, afbeelding 1 van 2 Razer Barracuda X Battery Replacement: stap 4, afbeelding 2 van 2
    • Unplug the battery from the socket.
    • Use a spudger to gently lift the battery up.
    • Remove the battery.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Micah Ortiz
247 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-3, Petersen Fall 2022 Lid van UMass Dartmouth, Team 2-3, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G3
4 Leden
7 handleidingen geschreven
7 opmerkingen
What is the voltage of the battery?
Bavo Van Rillaer - Antwoord
It’s a 3.7V battery.
Dániel Baranyi -
Battery info Barracuda X Wireless (2022) version but I believe the non 2022 version also:
55345PN2 / 1ICP6/35/51 1200mAh/4.44Wh
Dominick -
Si, 3,7 v se ve muy mal en la foto del Paso 4
Carlos López (España - Spain) - Antwoord
How small is that battery?? i took mine apart and i saw i got the wrong size battery in general.
JPStruggle - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 209
Altijd: 3,183
