Inleiding
This guide will show you how to remove a broken or malfunctioning pedal and replace it with a new one.
Onderdelen
  1. First take an 8 in adjustable crescent wrench and fit it around the base of the pedal.
    • First take an 8 in adjustable crescent wrench and fit it around the base of the pedal.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. To unscrew the chain side pedal twist the the wrench counter  clockwise. To unscrew the pedal that is on the side away from the chain, twist the wrench clockwise.
    • To unscrew the chain side pedal twist the the wrench counter clockwise.
    • To unscrew the pedal that is on the side away from the chain, twist the wrench clockwise.
  4. Continue turning the wrench until the pedal detaches from the crank arm.
    • Continue turning the wrench until the pedal detaches from the crank arm.
Conclusie
William Beechinor
124 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-49, Forte Fall 2012 Lid van Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Leden
5 handleidingen geschreven
Één commentaar
Thanks for info.
lanzofano - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 4
Afgelopen 30 Dagen: 7
Altijd: 1,262
