Ga door naar hoofdinhoud
Raleigh M20 Handlebars Replacement
Wat je nodig hebt
  1. Raleigh M20 Handlebars Replacement, Handlebars: stap 1, afbeelding 1 van 2 Raleigh M20 Handlebars Replacement, Handlebars: stap 1, afbeelding 2 van 2
    • Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...)
    • Using a 3/8" Allen wrench, loosen the nuts that hold the brake controls and gear shifters.
  2. Raleigh M20 Handlebars Replacement: stap 2, afbeelding 1 van 3 Raleigh M20 Handlebars Replacement: stap 2, afbeelding 2 van 3 Raleigh M20 Handlebars Replacement: stap 2, afbeelding 3 van 3
    • Place an Allen wrench (size doesn't matter) under the bike grip.
    • Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
  3. Raleigh M20 Handlebars Replacement: stap 3, afbeelding 1 van 2 Raleigh M20 Handlebars Replacement: stap 3, afbeelding 2 van 2
    • Slide off the gear shifters.
    • Slide off the brake controls.
  4. Raleigh M20 Handlebars Replacement: stap 4, afbeelding 1 van 3 Raleigh M20 Handlebars Replacement: stap 4, afbeelding 2 van 3 Raleigh M20 Handlebars Replacement: stap 4, afbeelding 3 van 3
    • Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
    • Lift the handlebars from the bike frame.
    • Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
    • Sit on the bike and make final adjustments to the positioning of the brakes and gears.
Conclusie
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
Jon Ribera
72 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-49, Forte Fall 2012 Lid van Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 2,097
