Ga door naar hoofdinhoud
RYOBI P422 Body Replacement
Wat je nodig hebt
  1. RYOBI P422 Body Replacement, Battery and Handle: stap 1, afbeelding 1 van 2 RYOBI P422 Body Replacement, Battery and Handle: stap 1, afbeelding 2 van 2
    • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
    • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
  2. RYOBI P422 Body Replacement, Body: stap 2, afbeelding 1 van 1
    • Lay the grinder flat on its side so the screws are facing up.
  3. RYOBI P422 Body Replacement: stap 3, afbeelding 1 van 3 RYOBI P422 Body Replacement: stap 3, afbeelding 2 van 3 RYOBI P422 Body Replacement: stap 3, afbeelding 3 van 3
    • Remove the four 1.8 cm screws from the lower and mid section of the body with the Torx T20 screwdriver.
    • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver.
  4. RYOBI P422 Body Replacement: stap 4, afbeelding 1 van 2 RYOBI P422 Body Replacement: stap 4, afbeelding 2 van 2
    • Now that the two halves are unscrewed, lift up the top half.
  5. RYOBI P422 Body Replacement: stap 5, afbeelding 1 van 3 RYOBI P422 Body Replacement: stap 5, afbeelding 2 van 3 RYOBI P422 Body Replacement: stap 5, afbeelding 3 van 3
    • Remove the safety trigger and the spring.
    • Be careful in removing the safety trigger, the pin may fall out as you are moving it.
  6. RYOBI P422 Body Replacement: stap 6, afbeelding 1 van 2 RYOBI P422 Body Replacement: stap 6, afbeelding 2 van 2
    • Lift up main trigger and spring together.
    • By lifting this trigger and spring out of the handle, you will pull double duty by lifting the black switch box off of its two support posts.
    • Slide the trigger off of the black switch box.
    • Be careful when removing trigger, the spring will be compressed and may move unexpectedly.
  7. RYOBI P422 Body Replacement: stap 7, afbeelding 1 van 3 RYOBI P422 Body Replacement: stap 7, afbeelding 2 van 3 RYOBI P422 Body Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Lift the battery lead bracket from its slot.
    • Use the PH 1 screwdriver to unscrew the two 0.7 cm screws that hold the 2.6 cm long brass bracket in place.
    • Use tweezers to remove the brass bracket.
    • During reassembly, remember to keep the spring inside the main trigger and against the bracket that is visible in the second of the accompanying photos.
  8. RYOBI P422 Body Replacement: stap 8, afbeelding 1 van 2 RYOBI P422 Body Replacement: stap 8, afbeelding 2 van 2
    • Flip the grinder over and lift off the second half of the body.
    • Now you can replace your damaged handles with a new pair.
Conclusie
John Lamanuzzi
229 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-6, Duarte Spring 2015 Lid van UMass Dartmouth, Team 3-6, Duarte Spring 2015
UMASSD-DUARTE-S15S3G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 16
Altijd: 1,394
