Inleiding
If your angle grinder suddenly stops working a common problem is that your brushes are worn out. Carbon brushes wear overtime so they will need to be replaced every so often. This replacement guide explains how the brushes can malfunction and how you can fix certain issues.
Wat je nodig hebt
Remove the brush caps from each side of the body using the 4 mm flat head screwdriver.
Één andere persoon heeft deze handleiding voltooid.
