Ga door naar hoofdinhoud
RYDIS H68 Pro Side Brush Motor Replacement
Wat je nodig hebt
  1. RYDIS H68 Pro Side Brush Motor Replacement, Battery: stap 1, afbeelding 1 van 2 RYDIS H68 Pro Side Brush Motor Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Side Brush Motor Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: stap 3, afbeelding 1 van 3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: stap 3, afbeelding 2 van 3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: stap 3, afbeelding 3 van 3
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Side Brush Motor Replacement: stap 4, afbeelding 1 van 3 RYDIS H68 Pro Side Brush Motor Replacement: stap 4, afbeelding 2 van 3 RYDIS H68 Pro Side Brush Motor Replacement: stap 4, afbeelding 3 van 3
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Side Brush Motor Replacement: stap 5, afbeelding 1 van 3 RYDIS H68 Pro Side Brush Motor Replacement: stap 5, afbeelding 2 van 3 RYDIS H68 Pro Side Brush Motor Replacement: stap 5, afbeelding 3 van 3
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Side Brush Motor Replacement, Side Brush Motor: stap 6, afbeelding 1 van 1
    • Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
    • Unlatch the latches indicated. It can be easily done with your finger.
    • Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
    • The reason for these first few steps is to avoid damaging the signal wires for the sensor.
  7. RYDIS H68 Pro Side Brush Motor Replacement: stap 7, afbeelding 1 van 1
    • This step just shows you how everything looks after the previous steps were completed.
    • There are sensors on both the left and right side. This can be done for either side.
  8. RYDIS H68 Pro Side Brush Motor Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the five 10mm screws using a Phillips #1 screwdriver.
  9. RYDIS H68 Pro Side Brush Motor Replacement: stap 9, afbeelding 1 van 1
    • The side brush motor can now be removed by lifting it up.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
jude auguste
108 Reputatie
1 Handleiding geschreven
USFT-Lacy-S17S005G2 Lid van USFT-Lacy-S17S005G2
Local Repair Groups
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 593
