Ga door naar hoofdinhoud
ROYALAXE R68 TKL Key Switches Replacement
Wat je nodig hebt
  1. ROYALAXE R68 TKL Key Switches Replacement, Key Switches: stap 1, afbeelding 1 van 2 ROYALAXE R68 TKL Key Switches Replacement, Key Switches: stap 1, afbeelding 2 van 2
    • Unplug the keyboard from its power source.
  2. ROYALAXE R68 TKL Key Switches Replacement: stap 2, afbeelding 1 van 1
    • Remove all keycaps with the keycap puller.
    • You can line up the keycaps in order or take a picture of your keyboard to make it easier to put them back on at the end.
  3. ROYALAXE R68 TKL Key Switches Replacement: stap 3, afbeelding 1 van 2 ROYALAXE R68 TKL Key Switches Replacement: stap 3, afbeelding 2 van 2
    • Clean the keyboard using a compressed air duster and a small brush or cotton swab.
    • You can also clean your keycaps by soaking them in a bowl with water and soap for about 30 minutes.
  4. ROYALAXE R68 TKL Key Switches Replacement: stap 4, afbeelding 1 van 2 ROYALAXE R68 TKL Key Switches Replacement: stap 4, afbeelding 2 van 2
    • Remove the switches with the switch puller.
    • Make sure to clamp on the switch vertically instead of horizontally. Then gently pull it out.
    • Taking out the switch by pulling horizontally could damage the switch.
  5. ROYALAXE R68 TKL Key Switches Replacement: stap 5, afbeelding 1 van 3 ROYALAXE R68 TKL Key Switches Replacement: stap 5, afbeelding 2 van 3 ROYALAXE R68 TKL Key Switches Replacement: stap 5, afbeelding 3 van 3
    • Make sure the copper part of the switch faces you when you try to insert the switch.
    • Insert the key switch as straight as possible and press down gently until you hear a click.
    • If you fail to line it up, it will bend the copper part under the switch. This will permanently damage the switch.
  6. ROYALAXE R68 TKL Key Switches Replacement: stap 6, afbeelding 1 van 2 ROYALAXE R68 TKL Key Switches Replacement: stap 6, afbeelding 2 van 2
    • Place keycaps in their respective position.
    • Make sure all keys are operating well.
    • Enjoy your new switches!
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Angie
163 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 4-5, Kershman Fall 2023 Lid van CSU Los Angeles, Team 4-5, Kershman Fall 2023
CSULA-KERSHMAN-F23S4G5
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 131
