Ga door naar hoofdinhoud
ROG Strix G15 G512LI M.2 SSD Replacement
Wat je nodig hebt
  1. ROG Strix G15 G512LI M.2 SSD Replacement, Removing The Cover: stap 1, afbeelding 1 van 1
    • Remove the screws from the compartment cover, As show in the diagram, unscrew the screws labeled "A" first. before unscrewing "B", Don't remove screw "B" from the cover.
  2. ROG Strix G15 G512LI M.2 SSD Replacement: stap 2, afbeelding 1 van 1
    • Remove the panel, but be careful as there are 2 cables linking the RGB light bar to the motherboard, carefully and gently detach them from the motherboard and lift the panel.
  3. ROG Strix G15 G512LI M.2 SSD Replacement, Installing The SSD: stap 3, afbeelding 1 van 2 ROG Strix G15 G512LI M.2 SSD Replacement, Installing The SSD: stap 3, afbeelding 2 van 2
    • Locate the M.2 SSD slots, the First and Third slots both support SATA and PCIe NVMe M.2 SSDs, and the second M.2 Slot only supports PCIe NVMe SSDs
    • Next, Insert the NVMe SSD, and screw the SSD into place with the retaining screws
Conclusie
Één andere persoon heeft deze handleiding voltooid.
June
590 Reputatie
3 handleidingen geschreven
2 opmerkingen
how to fix the light bar i have one side wont light on
fethallah - Antwoord
are the m.2 nvme slot PCIe 3.0x4 and are they all the same speed or type?
Yousef Suwaidan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 204
Altijd: 7,834
