Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Frontal/Back View- Dimensions: (LxWxD) 107mm x 50mm x 14mm (4.02" x 1.97" x .55") <- For those in America :) Weight: 96g or 3.10oz
Speaker
Status LED
High-res 240x260 Color LCD display
Red Trackball
1.3MP Camera
Flash
Back Cover Latch
Side View!
3.5mm Stereo Headset Jack
USB 2.0 Data/Charging Port
Micro SD Card Slot
Camera/Quick Access Button
Volume Up/Down Button
Quick Access Button
Lanyard/Accessory Attachment
Top/Bottom!
This phone his seen it's share of scratches!
Mute/Ringer Off Button
Microphone
Press down on clip and remove back cover.
Push Battery from top to bottom and pull up to remove.
Battery: Standby time- 216 hours/Call time- 4 hours
Clip
Back cover
1.3MP Camera
Flash
QuALCOMM 3G CDMA
Phone information sticker
Torx T5 screws
Insert curved point metal spudger into gap between keyboard and bottom bezel cap.
Bottom Bezel Cap
Pull up and push away to lift bezel.
Hold this cap with your thumb and flip the phone around.
Insert spudger under bezel and lift on both sides.
Pry Here
The Bezel Cap should pop off at this point revealing two more T5 screws!
Two T5 Screws
Remove the two T5 Screws and set them aside.
The two T5 screws and their respective holes
Start at the top of one of the sides of the phone and pry off the silver sides with a spudger or your fingers.
Once you have removed both sides set them aside
The silver sides
Various holes, buttons and slots
Headphone Jack
USB 2.0 Port
Micro SD Card Slot
Camera Button
Up and Down Buttons
Quick Access Button
Pry front cover and back cover off of LCD and circuit board.
Separate the three parts and set them down.
Back plastic assembly
LCD and Logic Board
Front plastic assembly and keypad+trackball
Trackball (Removable). Pop it out from the back.
Display Glass (Removable). Pry from the top to break glue seal, pry the rest of with your fingers.
Keypad
LCD and connector above it to the left (Removable). Remove connector with spudger and free LCD from clips.
Keypad connector (Keypad was removed). To remove pry connector up off of logic board.
Battery Connector
Various chips under metal heat sinks. Sorry I won't remove them the phone is still good and I don't want to risk damaging it :(
Speaker (Removable by Soldering)
Keyboard Connector
Trackball (Remove by poking out)
1.3MP Camera (Removable by Soldering)
From left to right: Headphone jack, Antenna?, USB Port, Micro SD Card Slot. All of the above are removable by soldering.
Battery Connector (Removable by pulling it straight out of it's slot)
Various chips covered by heatsinks
Here it is, everything all laid out.
Back Cover and Battery
T5 Screws
Bezel cap
Shiny Side pieces
Front Plastic Assembly
Back Plastic Assembly
LCD and Logic Board
