Ga door naar hoofdinhoud
RIDGID R84015 X2 Disassembly
Wat je nodig hebt
  1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: stap 1, afbeelding 1 van 2 RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: stap 1, afbeelding 2 van 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Disassembly: stap 2, afbeelding 1 van 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Disassembly: stap 3, afbeelding 1 van 2 RIDGID R84015 X2 Disassembly: stap 3, afbeelding 2 van 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: stap 4, afbeelding 1 van 1
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  5. RIDGID R84015 X2 Disassembly: stap 5, afbeelding 1 van 1
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  6. RIDGID R84015 X2 Disassembly: stap 6, afbeelding 1 van 1
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  7. RIDGID R84015 X2 Disassembly: stap 7, afbeelding 1 van 1
    • Make sure plastic is not broken and switch is not stuck.
Eindstreep
Brian
97 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-48, Garner Spring 2010 Lid van Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Leden
10 handleidingen geschreven
Één opmerking
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 13,623
