Ga door naar hoofdinhoud
RIDGID R32104 Saw Blade Replacement
Wat je nodig hebt
  1. RIDGID R32104 Saw Blade Replacement, Saw Blade: stap 1, afbeelding 1 van 1
    • Turn off your saw and unplug before starting.
    • The RIDGID R32104 Saw did not come with a blade, so paper was used to mime the actions needed.
    • Place the Worm Drive Saw on a sturdy surface.
    • The blade is located within its upper blade guard and lower swing guard assembly.
  2. RIDGID R32104 Saw Blade Replacement: stap 2, afbeelding 1 van 2 RIDGID R32104 Saw Blade Replacement: stap 2, afbeelding 2 van 2
    • Using a H-6 mm Allen Key, remove the 3/8 - 16 UNC LH screw, washer, and outer blade washer that fixes the blade in place.
    • In order to unscrew this, you must turn the screw clockwise to loosen it.
  3. RIDGID R32104 Saw Blade Replacement: stap 3, afbeelding 1 van 1
    • Adjust the lower swing guard to properly grab the blade.
  4. RIDGID R32104 Saw Blade Replacement: stap 4, afbeelding 1 van 1
    • Remove the blade by gingerly grabbing towards its center, preventing any injury from occurring.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lucas Pimentel
1.010 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team S5-G1, Julie Spring 2019 Lid van UMass Dartmouth, Team S5-G1, Julie Spring 2019
UMASSD-JULIE-S19S5G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 23
Altijd: 1,044
