Ga door naar hoofdinhoud
RIDGID R32104 Motor Bearings Replacement
Wat je nodig hebt
  1. RIDGID R32104 Motor Bearings Replacement, Motor Brush: stap 1, afbeelding 1 van 2 RIDGID R32104 Motor Bearings Replacement, Motor Brush: stap 1, afbeelding 2 van 2
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Bearings Replacement: stap 2, afbeelding 1 van 2 RIDGID R32104 Motor Bearings Replacement: stap 2, afbeelding 2 van 2
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Bearings Replacement: stap 3, afbeelding 1 van 1
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
  4. RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: stap 4, afbeelding 1 van 3 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: stap 4, afbeelding 2 van 3 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: stap 4, afbeelding 3 van 3
    • Maneuver the RIDGID saw, in order to easily remove the upper blade guard assembly.
    • Using the T20 Torx Screwdriver, remove the four 4/10 cm screws that attach to the gear box.
  5. RIDGID R32104 Motor Bearings Replacement: stap 5, afbeelding 1 van 2 RIDGID R32104 Motor Bearings Replacement: stap 5, afbeelding 2 van 2
    • Using the T50 Torx Screwdriver, remove the one 5/10 screw that attach to the gear box.
  6. RIDGID R32104 Motor Bearings Replacement: stap 6, afbeelding 1 van 2 RIDGID R32104 Motor Bearings Replacement: stap 6, afbeelding 2 van 2
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach to the handle of the device.
  7. RIDGID R32104 Motor Bearings Replacement: stap 7, afbeelding 1 van 2 RIDGID R32104 Motor Bearings Replacement: stap 7, afbeelding 2 van 2
    • Maneuver the saw to get to the base plate.
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach the upper blade guard’s base plate to the main housing assembly.
  8. RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: stap 8, afbeelding 1 van 2 RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: stap 8, afbeelding 2 van 2
    • Using the T20 Torx Screwdriver, remove the four 10 cm screws that attaches the main housing assembly to the gear box.
  9. RIDGID R32104 Motor Bearings Replacement, Gear Box: stap 9, afbeelding 1 van 2 RIDGID R32104 Motor Bearings Replacement, Gear Box: stap 9, afbeelding 2 van 2
    • Wiggle out the gear box to easily gain access to the motor rotor.
    • Once taken out, the motor rotor is easily accessible.
  10. RIDGID R32104 Motor Bearings Replacement, Motor Rotor: stap 10, afbeelding 1 van 3 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: stap 10, afbeelding 2 van 3 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: stap 10, afbeelding 3 van 3
    • The motor rotor is lodged in between the armature and can be identified as a rod containing a fan blade.
    • Carefully remove the motor rotor from the device.
  11. RIDGID R32104 Motor Bearings Replacement, Motor Bearings: stap 11, afbeelding 1 van 1
    • The bearings are located on the opposite end of the motor rotor, from where the fan blade was.
    • Carefully remove the motor bearings from the motor rotor.
Conclusie
Lucas Pimentel
1.010 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team S5-G1, Julie Spring 2019 Lid van UMass Dartmouth, Team S5-G1, Julie Spring 2019
UMASSD-JULIE-S19S5G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 545
