Inleiding
If your RIDGID Belt Sander R2740 is making abnormal sounds the cause could be from a worn or damaged ball bearing. This guide will teach you how to replace the ball bearing. For this guide, you will need a screwdriver with a T20 head and a hammer.
Wat je nodig hebt
Orient the belt sander so that the AirGuard Technology logo is facing you.
Remove the nine 19mm, two 51mm and one 32 mm screws that hold the cover into place.
Remove the cover from the belt sander.
Één andere persoon heeft deze handleiding voltooid.
