Ga door naar hoofdinhoud
RIDGID BELT SANDER R2740 Timing Belt Replacement
Wat je nodig hebt
  1. RIDGID BELT SANDER R2740 Timing Belt Replacement, Timing Belt: stap 1, afbeelding 1 van 1
    • Orientate the sander so that the timing belt housing is facing you.
    • Remove the 19mm T20 screw from the center of the timing belt housing.
  2. RIDGID BELT SANDER R2740 Timing Belt Replacement: stap 2, afbeelding 1 van 1
    • Remove the timing belt housing.
  3. RIDGID BELT SANDER R2740 Timing Belt Replacement: stap 3, afbeelding 1 van 1
    • Use your finger or a screwdriver to apply pressure on the belt away from the sander near one of the small wheels.
    • Rotate the large wheel while applying pressure until the timing belt is free from the wheels.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 996
