Ga door naar hoofdinhoud
RICATECH-RTT22 Turntable Belt Replacement
Wat je nodig hebt
  1. RICATECH-RTT22 Turntable Belt Replacement, Belt: stap 1, afbeelding 1 van 3 RICATECH-RTT22 Turntable Belt Replacement, Belt: stap 1, afbeelding 2 van 3 RICATECH-RTT22 Turntable Belt Replacement, Belt: stap 1, afbeelding 3 van 3
    • Remove the arm holder by moving the needle to the side and lifting up.
    • Remove the rubber pad by lifting it up.
  2. RICATECH-RTT22 Turntable Belt Replacement: stap 2, afbeelding 1 van 3 RICATECH-RTT22 Turntable Belt Replacement: stap 2, afbeelding 2 van 3 RICATECH-RTT22 Turntable Belt Replacement: stap 2, afbeelding 3 van 3
    • Flip over the record player. There should be screws (10mm phillips head) on the back.
    • Use your phillips head screwdriver to remove each screw (keep them in a safe place for later).
  3. RICATECH-RTT22 Turntable Belt Replacement: stap 3, afbeelding 1 van 3 RICATECH-RTT22 Turntable Belt Replacement: stap 3, afbeelding 2 van 3 RICATECH-RTT22 Turntable Belt Replacement: stap 3, afbeelding 3 van 3
    • There will be three wires connecting the top to the bottom. Disconnect them carefully.
    • Put the back component of the record player to the side.
  4. RICATECH-RTT22 Turntable Belt Replacement: stap 4, afbeelding 1 van 3 RICATECH-RTT22 Turntable Belt Replacement: stap 4, afbeelding 2 van 3 RICATECH-RTT22 Turntable Belt Replacement: stap 4, afbeelding 3 van 3
    • Use your phillips head screwdriver to remove the three screws (8mm phillips head) holding the motor in place.
    • Keep in mind that there is some pressure on the motor, since the belt holds together the motor and turntable.
  5. RICATECH-RTT22 Turntable Belt Replacement: stap 5, afbeelding 1 van 2 RICATECH-RTT22 Turntable Belt Replacement: stap 5, afbeelding 2 van 2
    • Unbolt (6mm bolt) the turntable from the housing using your wrench.
    • Since the turntable is designed to rotate, make sure the other side of the pin is kept from rotating while unbolting.
  6. RICATECH-RTT22 Turntable Belt Replacement: stap 6, afbeelding 1 van 2 RICATECH-RTT22 Turntable Belt Replacement: stap 6, afbeelding 2 van 2
    • Carefully removed the rubber band from around the motor and extract the turntable from the device.
  7. RICATECH-RTT22 Turntable Belt Replacement: stap 7, afbeelding 1 van 1
    • Remove the damaged belt. Place the new belt around the turntable.
  8. RICATECH-RTT22 Turntable Belt Replacement: stap 8, afbeelding 1 van 2 RICATECH-RTT22 Turntable Belt Replacement: stap 8, afbeelding 2 van 2
    • Follow the instructions backwards to reassemble the record player.
Eindstreep
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 814
