Ga door naar hoofdinhoud
RCA RP3715A Display Replacement
Wat je nodig hebt
  1. RCA RP3715A Display Replacement, Reaching the battery terminal.: stap 1, afbeelding 1 van 2 RCA RP3715A Display Replacement, Reaching the battery terminal.: stap 1, afbeelding 2 van 2
    • Push down on the clip to release pressure. The pull off the plastic cover.
  2. RCA RP3715A Display Replacement, Replacing the battery: stap 2, afbeelding 1 van 1
    • Remove the 9-volt battery from the battery terminal.
  3. RCA RP3715A Display Replacement, Getting inside the device.: stap 3, afbeelding 1 van 1
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  4. RCA RP3715A Display Replacement, Relieve extension cord tension.: stap 4, afbeelding 1 van 3 RCA RP3715A Display Replacement, Relieve extension cord tension.: stap 4, afbeelding 2 van 3 RCA RP3715A Display Replacement, Relieve extension cord tension.: stap 4, afbeelding 3 van 3
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  5. RCA RP3715A Display Replacement: stap 5, afbeelding 1 van 2 RCA RP3715A Display Replacement: stap 5, afbeelding 2 van 2
    • Using flathead screwdriver undo the release tabs.
  6. RCA RP3715A Display Replacement: stap 6, afbeelding 1 van 3 RCA RP3715A Display Replacement: stap 6, afbeelding 2 van 3 RCA RP3715A Display Replacement: stap 6, afbeelding 3 van 3
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  7. RCA RP3715A Display Replacement: stap 7, afbeelding 1 van 2 RCA RP3715A Display Replacement: stap 7, afbeelding 2 van 2
    • Pry open both tabs to remove the topside of the clock.
  8. RCA RP3715A Display Replacement, Speaker Replacement: stap 8, afbeelding 1 van 1
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
  9. RCA RP3715A Display Replacement, Detaching the front panel: stap 9, afbeelding 1 van 1
    • Remove the two 10 mm Phillip's #1 screws.
  10. RCA RP3715A Display Replacement: stap 10, afbeelding 1 van 1
    • Remove the gray panel from the frame.
  11. RCA RP3715A Display Replacement, Unlatch release tabs: stap 11, afbeelding 1 van 3 RCA RP3715A Display Replacement, Unlatch release tabs: stap 11, afbeelding 2 van 3 RCA RP3715A Display Replacement, Unlatch release tabs: stap 11, afbeelding 3 van 3
    • The two latches located in the picture will help take off the display.
    • Remove the display.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Myles Waiters
370 Reputatie
3 handleidingen geschreven
USF Tampa, Team 10-5, Brown Fall 2014 Lid van USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 345
