Wat je nodig hebt
Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
Uncoil the wires. If necessary, use a wire stripper to expose more of the wire.
Solder the wires to the base of the speaker. The metal of the wire should be touching exposed metal on the speaker. Insure that the colors of the wires match the picture.
Bijna klaar!
To reassemble your device, follow the instructions in steps 1 and 2 in reverse order.
Conclusie
