Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Gearchiveerd
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Gearchiveerd
Inleiding
If the screen of the device becomes cracked or stops registering touch commands, use the following guide to replace the screen.
  1. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
    • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
  2. Remove back cover with lever tool, exposing the battery and motherboard. Remove back cover with lever tool, exposing the battery and motherboard.
    • Remove back cover with lever tool, exposing the battery and motherboard.
  3. Using the tweezers, remove the black tape connecting the screen to the motherboard. Using the tweezers, remove the black tape connecting the screen to the motherboard.
    • Using the tweezers, remove the black tape connecting the screen to the motherboard.
  4. Pull up the switch to remove the input connector. Pull up the switch to remove the input connector.
    • Pull up the switch to remove the input connector.
  5. Heat the iOpener in the microwave, following the instructions provided with the tool. Lay the heated iOpener on the front screen for two minutes to soften the connection of the screen to the tablet.
    • Heat the iOpener in the microwave, following the instructions provided with the tool. Lay the heated iOpener on the front screen for two minutes to soften the connection of the screen to the tablet.
  6. Use the suction cup and lever tool tool to pry the front screen from the tablet. Use the suction cup and lever tool tool to pry the front screen from the tablet.
    • Use the suction cup and lever tool tool to pry the front screen from the tablet.
Conclusie
mikayla
408 Reputatie
2 handleidingen geschreven
Clemson, Team 14-4, Shirley Spring 2015 Lid van Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Leden
15 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,189
