Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Gearchiveerd
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Gearchiveerd
Inleiding
After noticing your battery life deteriorate or you notice a bulge in the back of the device, it is time to replace the battery. In this guide, you will be removing the following parts:
  1. 1. Back Cover
  2. 2. Battery
  1. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
    • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
  2. Remove back cover with lever tool, exposing the battery and motherboard. Remove back cover with lever tool, exposing the battery and motherboard. Remove back cover with lever tool, exposing the battery and motherboard.
    • Remove back cover with lever tool, exposing the battery and motherboard.
  3. Remove the two black tape strips from the battery pack. Remove the two black tape strips from the battery pack. Remove the two black tape strips from the battery pack.
    • Remove the two black tape strips from the battery pack.
  4. Remove the battery pack by carefully prying the battery back from the front cover. Then remove the wires connecting the battery to the motherboard at the motherboard using the tweezers. Remove the battery pack by carefully prying the battery back from the front cover. Then remove the wires connecting the battery to the motherboard at the motherboard using the tweezers. Remove the battery pack by carefully prying the battery back from the front cover. Then remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
    • Remove the battery pack by carefully prying the battery back from the front cover. Then remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
  5. Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
    • Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
  6. The new wires must be soldered back into place on the motherboard at the original location. For tips on soldering techniques, see this Soldering Guide For tips on soldering techniques, see this Soldering Guide
    • The new wires must be soldered back into place on the motherboard at the original location.
    • For tips on soldering techniques, see this Soldering Guide
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Justin
407 Reputatie
2 handleidingen geschreven
Clemson, Team 14-4, Shirley Spring 2015 Lid van Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Leden
15 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,059
