Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
The camera is located in the corner of the motherboard, attached by a ribbon cable. Lift up on the black latch that is holding in the ribbon cable and the cable should pop up and out.
Once the cable is removed from the motherboard, the entire camera can simply be removed from the device.
Één opmerking
Where can I get the replacement parts (camera and flex cable)
