Inleiding
Replacing the main motherboard and attached components involves loosening or disconnecting each component individually before replacing the whole unit.
Wat je nodig hebt
Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
Remove the battery by first removing the electrical tape holding it down. Then begin gently prying underneath it and around the edges with your plastic opening tool, until the battery is loose.
To reassemble your device, follow these instructions in reverse order - replacing all tapes and adhesives as you proceed.
7 andere personen hebben deze handleiding voltooid.
2 opmerkingen
We did a reset. When our tablet boots up we get a message "google account manager has stopped running". We can not access the settings. How do we fix this error message?
how about a screen that has lines
