Inleiding
This guide will show how to replace buttons on the RCA RCR8622.
Wat je nodig hebt
Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
Remove the two 11mm screws from the motherboard with the Phillip's #1 screwdriver.
Squeeze the 2 metal prongs on the interior of the motherboard inward until a clicking noise is heard.
Identify which button needs to be changed out. There will be lables on the board indicating functionality of each button.
Flip the board over and find the button by the circles on the board.
Solder the 2 pins off the button and pinch the top of the button on the other side to pull off.
