Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using a separating tool, look for a seam in the plastic casing that looks most accessible.
Use the prying tool to separate the front and back casing, working your way around the perimeter.
Utilize a card tool or a pick to assist in keeping the case separated.
Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
Remove the yellow tape securing the speaker to the back casing.
Use the separating tool to pry the speaker from its surface.
Cut or desolder the wires to replace or repair the speaker.
