Ga door naar hoofdinhoud
  1. Using a separating tool, look for a seam in the plastic casing that looks most accessible. Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. Use the separating tool to pry the speaker from its surface. Use caution when removing the speaker, you may damage the screen.
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it. Peel back the beige tape while holding down the camera ribbon cable to prevent tears Peel back the beige tape while holding down the camera ribbon cable to prevent tears
    • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
    • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
  5. Lift the locking tab that is securing the camera ribbon cable. Slide the ribbon cable out from the connector and remove from casing.
    • Lift the locking tab that is securing the camera ribbon cable.
    • Slide the ribbon cable out from the connector and remove from casing.
  6. Use a P00 Phillips screwdriver to remove the three screws securing the button board.
    • Use a P00 Phillips screwdriver to remove the three screws securing the button board.
    • Desolder the contacts on the button board to remove or replace it.
Conclusie
Dayne Russell
401 Reputatie
4 handleidingen geschreven
Pasco Hernando, Team 1-1, Prince Winter 2015 Lid van Pasco Hernando, Team 1-1, Prince Winter 2015
PHSC-PRINCE-W15S1G1
6 Leden
10 handleidingen geschreven
Één commentaar
What is the part number for the Power/Volume Buttons? Where can I purchase one?
EvanSnow - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 866
