Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Deze stap is niet vertaald. Help het te vertalen
    Using a separating tool, look for a seam in the plastic casing that looks most accessible. Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. Deze stap is niet vertaald. Help het te vertalen
    Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. Deze stap is niet vertaald. Help het te vertalen
    Use the separating tool to pry the speaker from its surface. Use caution when removing the speaker, you may damage the screen.
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. Deze stap is niet vertaald. Help het te vertalen
    Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it. Peel back the beige tape while holding down the camera ribbon cable to prevent tears Peel back the beige tape while holding down the camera ribbon cable to prevent tears
    • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
    • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
  5. Deze stap is niet vertaald. Help het te vertalen
    Lift the locking tab that is securing the camera ribbon cable. Slide the ribbon cable out from the connector and remove from casing.
    • Lift the locking tab that is securing the camera ribbon cable.
    • Slide the ribbon cable out from the connector and remove from casing.
  6. Deze stap is niet vertaald. Help het te vertalen
    Use a P00 Phillips screwdriver to remove the three screws securing the button board.
    • Use a P00 Phillips screwdriver to remove the three screws securing the button board.
    • Desolder the contacts on the button board to remove or replace it.
  7. Deze stap is niet vertaald. Help het te vertalen
    Peel off the black tape on the battery and main-board. Peel off the black tape securing the screen ribbon cable to the back of the screen.
    • Peel off the black tape on the battery and main-board.
    • Peel off the black tape securing the screen ribbon cable to the back of the screen.
    • Use caution to avoid damaging either ribbon cable.
  8. Deze stap is niet vertaald. Help het te vertalen
    Slide out the ribbon cable lock that is securing the screen ribbon cable. Move the ribbon cable out of the way using tape if necessary.
    • Slide out the ribbon cable lock that is securing the screen ribbon cable.
    • Move the ribbon cable out of the way using tape if necessary.
  9. Deze stap is niet vertaald. Help het te vertalen
    Remove the yellow tape securing the battery to the screen. Use a plastic card or pick to separate the battery from the screen.
    • Remove the yellow tape securing the battery to the screen.
    • Use a plastic card or pick to separate the battery from the screen.
    • Do not bend or puncture battery, battery is difficult to separate from screen.
    • Cut or desolder the wires on the battery to remove or replace it.
  10. Deze stap is niet vertaald. Help het te vertalen
    Peel the WiFi antenna off of the monitor and move out of the way.
    • Peel the WiFi antenna off of the monitor and move out of the way.
  11. Deze stap is niet vertaald. Help het te vertalen
    Remove the black tape on the screen and the main-board. Lift the ribbon cable lock securing the digitizer ribbon cable. Slide out the digitizer ribbon cable and move away from the device, use tape to secure if necessary.
    • Remove the black tape on the screen and the main-board.
    • Lift the ribbon cable lock securing the digitizer ribbon cable.
    • Slide out the digitizer ribbon cable and move away from the device, use tape to secure if necessary.
  12. Deze stap is niet vertaald. Help het te vertalen
    Use a P00 Phillips screwdriver to remove the three screws securing the main-board to the back casing.
    • Use a P00 Phillips screwdriver to remove the three screws securing the main-board to the back casing.
  13. Deze stap is niet vertaald. Help het te vertalen
    Lift the main-board up and away from the ports to reveal the microphone. Use tweezers to remove the microphone from the black silicone. Move the main-board off the screen.
    • Lift the main-board up and away from the ports to reveal the microphone.
    • Use tweezers to remove the microphone from the black silicone.
    • Move the main-board off the screen.
  14. Deze stap is niet vertaald. Help het te vertalen
    Use a separator tool to lift the screen from the port side of the casing and remove it. To reassemble the device, follow these steps in reverse unless specified otherwise.
    • Use a separator tool to lift the screen from the port side of the casing and remove it.
    • To reassemble the device, follow these steps in reverse unless specified otherwise.
Eindstreep
9 andere personen hebben deze handleiding voltooid.
Tyler Schuster
461 Reputatie
1 Handleiding geschreven
Pasco Hernando, Team 1-1, Prince Winter 2015 Lid van Pasco Hernando, Team 1-1, Prince Winter 2015
PHSC-PRINCE-W15S1G1
6 Leden
10 handleidingen geschreven
4 Opmerkingen
Gracias y ademas la buenas fotografias ayudaron una inmesidad.
Kl
Klaus laage - Antwoord
Nothing spectacular happened I just turned on my tablet today and voila! My display is crazed on part of the screen! I read these steps a couple times and I just don't understand how if this process is intended to replace the display screen a display screen isn't listed as a necessary part purchase. I have faith in reader generated sites so please help!
Denise Engle - Antwoord
Denise a new display screen would need to be purchased. Unless you absolutely have to have this particular tablet fixed I suggest buying a new one.
Chris Blackwell -
hola, podrás tener este repuesto de la pantalla lcd para la venta para ese modelo?
gracias
William Weygel
williamw666@hotmail.com
William Weygel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 6,038
