Ga door naar hoofdinhoud
RCA Pro10 Edition Display Screen Replacement
Wat je nodig hebt
  1. RCA Pro10 Edition Display Screen Replacement, Speaker: stap 1, afbeelding 1 van 2 RCA Pro10 Edition Display Screen Replacement, Speaker: stap 1, afbeelding 2 van 2
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Display Screen Replacement: stap 2, afbeelding 1 van 1
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Display Screen Replacement: stap 3, afbeelding 1 van 2 RCA Pro10 Edition Display Screen Replacement: stap 3, afbeelding 2 van 2
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. RCA Pro10 Edition Display Screen Replacement, Camera: stap 4, afbeelding 1 van 3 RCA Pro10 Edition Display Screen Replacement, Camera: stap 4, afbeelding 2 van 3 RCA Pro10 Edition Display Screen Replacement, Camera: stap 4, afbeelding 3 van 3
    • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
    • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
  5. RCA Pro10 Edition Display Screen Replacement: stap 5, afbeelding 1 van 2 RCA Pro10 Edition Display Screen Replacement: stap 5, afbeelding 2 van 2
    • Lift the locking tab that is securing the camera ribbon cable.
    • Slide the ribbon cable out from the connector and remove from casing.
  6. RCA Pro10 Edition Display Screen Replacement, Power/Volume Buttons: stap 6, afbeelding 1 van 1
    • Use a P00 Phillips screwdriver to remove the three screws securing the button board.
    • Desolder the contacts on the button board to remove or replace it.
  7. RCA Pro10 Edition Display Screen Replacement, Battery: stap 7, afbeelding 1 van 2 RCA Pro10 Edition Display Screen Replacement, Battery: stap 7, afbeelding 2 van 2
    • Peel off the black tape on the battery and main-board.
    • Peel off the black tape securing the screen ribbon cable to the back of the screen.
    • Use caution to avoid damaging either ribbon cable.
  8. RCA Pro10 Edition Display Screen Replacement: stap 8, afbeelding 1 van 2 RCA Pro10 Edition Display Screen Replacement: stap 8, afbeelding 2 van 2
    • Slide out the ribbon cable lock that is securing the screen ribbon cable.
    • Move the ribbon cable out of the way using tape if necessary.
  9. RCA Pro10 Edition Display Screen Replacement: stap 9, afbeelding 1 van 2 RCA Pro10 Edition Display Screen Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • Remove the yellow tape securing the battery to the screen.
    • Use a plastic card or pick to separate the battery from the screen.
    • Do not bend or puncture battery, battery is difficult to separate from screen.
    • Cut or desolder the wires on the battery to remove or replace it.
  10. RCA Pro10 Edition Display Screen Replacement, Display Screen: stap 10, afbeelding 1 van 1
    • Peel the WiFi antenna off of the monitor and move out of the way.
  11. RCA Pro10 Edition Display Screen Replacement: stap 11, afbeelding 1 van 3 RCA Pro10 Edition Display Screen Replacement: stap 11, afbeelding 2 van 3 RCA Pro10 Edition Display Screen Replacement: stap 11, afbeelding 3 van 3
    • Remove the black tape on the screen and the main-board.
    • Lift the ribbon cable lock securing the digitizer ribbon cable.
    • Slide out the digitizer ribbon cable and move away from the device, use tape to secure if necessary.
  12. RCA Pro10 Edition Display Screen Replacement: stap 12, afbeelding 1 van 1
    • Use a P00 Phillips screwdriver to remove the three screws securing the main-board to the back casing.
  13. RCA Pro10 Edition Display Screen Replacement: stap 13, afbeelding 1 van 3 RCA Pro10 Edition Display Screen Replacement: stap 13, afbeelding 2 van 3 RCA Pro10 Edition Display Screen Replacement: stap 13, afbeelding 3 van 3
    • Lift the main-board up and away from the ports to reveal the microphone.
    • Use tweezers to remove the microphone from the black silicone.
    • Move the main-board off the screen.
  14. RCA Pro10 Edition Display Screen Replacement: stap 14, afbeelding 1 van 2 RCA Pro10 Edition Display Screen Replacement: stap 14, afbeelding 2 van 2
    • Use a separator tool to lift the screen from the port side of the casing and remove it.
    • To reassemble the device, follow these steps in reverse unless specified otherwise.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Tyler Schuster
476 Reputatie
1 Handleiding geschreven
Pasco Hernando, Team 1-1, Prince Winter 2015 Lid van Pasco Hernando, Team 1-1, Prince Winter 2015
PHSC-PRINCE-W15S1G1
6 Leden
10 handleidingen geschreven
4Gids Commentaar
Gracias y ademas la buenas fotografias ayudaron una inmesidad.
Kl
Klaus laage - Antwoord
Nothing spectacular happened I just turned on my tablet today and voila! My display is crazed on part of the screen! I read these steps a couple times and I just don't understand how if this process is intended to replace the display screen a display screen isn't listed as a necessary part purchase. I have faith in reader generated sites so please help!
Denise Engle - Antwoord
Denise a new display screen would need to be purchased. Unless you absolutely have to have this particular tablet fixed I suggest buying a new one.
Chris Blackwell -
hola, podrás tener este repuesto de la pantalla lcd para la venta para ese modelo?
gracias
William Weygel
williamw666@hotmail.com
William Weygel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 6,418
