Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using a separating tool, look for a seam in the plastic casing that looks most accessible.
Use the prying tool to separate the front and back casing, working your way around the perimeter.
Utilize a card tool or a pick to assist in keeping the case separated.
Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
Remove the yellow tape securing the speaker to the back casing.
Use the separating tool to pry the speaker from its surface.
Cut or desolder the wires to replace or repair the speaker.
Peel off the black tape on the battery and main-board.
Peel off the black tape securing the screen ribbon cable to the back of the screen.
Slide out the ribbon cable lock that is securing the screen ribbon cable.
Move the ribbon cable out of the way using tape if necessary.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99-
Remove the yellow tape securing the battery to the screen.
Use a plastic card or pick to separate the battery from the screen.
Cut or desolder the wires on the battery to remove or replace it.
10 andere personen hebben deze handleiding voltooid.
