Ga door naar hoofdinhoud
RCA Pro10 Edition Battery Replacement
Wat je nodig hebt
  1. RCA Pro10 Edition Battery Replacement, Speaker: stap 1, afbeelding 1 van 2 RCA Pro10 Edition Battery Replacement, Speaker: stap 1, afbeelding 2 van 2
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Battery Replacement: stap 2, afbeelding 1 van 1
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Battery Replacement: stap 3, afbeelding 1 van 2 RCA Pro10 Edition Battery Replacement: stap 3, afbeelding 2 van 2
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. RCA Pro10 Edition Battery Replacement, Battery: stap 4, afbeelding 1 van 2 RCA Pro10 Edition Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Peel off the black tape on the battery and main-board.
    • Peel off the black tape securing the screen ribbon cable to the back of the screen.
    • Use caution to avoid damaging either ribbon cable.
  5. RCA Pro10 Edition Battery Replacement: stap 5, afbeelding 1 van 2 RCA Pro10 Edition Battery Replacement: stap 5, afbeelding 2 van 2
    • Slide out the ribbon cable lock that is securing the screen ribbon cable.
    • Move the ribbon cable out of the way using tape if necessary.
  6. RCA Pro10 Edition Battery Replacement: stap 6, afbeelding 1 van 2 RCA Pro10 Edition Battery Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Remove the yellow tape securing the battery to the screen.
    • Use a plastic card or pick to separate the battery from the screen.
    • Do not bend or puncture battery, battery is difficult to separate from screen.
    • Cut or desolder the wires on the battery to remove or replace it.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Dayne Russell
401 Reputatie
4 handleidingen geschreven
Pasco Hernando, Team 1-1, Prince Winter 2015 Lid van Pasco Hernando, Team 1-1, Prince Winter 2015
PHSC-PRINCE-W15S1G1
6 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 23
Altijd: 15,943
