Inleiding
To remove the main board, we will first remove the main cover. Then we will remove the black plastic coating. Next, we will remove the button control panel and the screen. Finally, we will unscrew the back cover to free the main board.
Wat je nodig hebt
For this procedure, you will need tweezers, a prying tool, and a Phillips J000 screwdriver.
Using the prying tool, insert the tip of the tool in between the black plastic and the back cover of the device.
Pull upward to pry the black plastic away from the device. It will come off in pieces, but this is okay.
There will be thin black plastic surrounding four clear pieces where the buttons used to be located. Remove this as well.
Now you should be able to see the main board. A small gold connector strip will connect the screen to the main board.
Locate a small white rectangular connector found at the top middle of the main board.
Using a prying tool or your fingernail, move the black plastic piece located at the bottom of the white connector to an upward position (toward the screen).
This should free the gold connector strip and allow you to remove the screen.
