Inleiding
This guide is for the removal of a damaged or broken motherboard in the RCA Maven Pro 11 Tablet. For this guide you will need a Phillip’s head screwdriver and a prying tool to open the tablet and remove the necessary pieces.
Wat je nodig hebt
Use a Phillip's head screwdriver to unscrew the screws that secure the back cover in place. There are 6 screws in total (4 black, 2 silver).
On the long edge of the motherboard, remove all of the ribbon and bundled cables.
The ZIF connections are removed by lifting up the small black tab on the connector and simply pulling out the ribbon cable(s).
Insert a spudger or plastic opening tool under the lip of the white bundled cable connector(s), and push the connector(s) free.
