Ga door naar hoofdinhoud
RCA Lyra X2400 flash card reader replacement
Wat je nodig hebt
  1. RCA Lyra X2400 flash card reader replacement, Battery: stap 1, afbeelding 1 van 3 RCA Lyra X2400 flash card reader replacement, Battery: stap 1, afbeelding 2 van 3 RCA Lyra X2400 flash card reader replacement, Battery: stap 1, afbeelding 3 van 3
    • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
    • Remove the battery plate.
    • Place your finger at the bottom of the battery.
    • Lift up on the battery until it pops out from the LYRA X2400.
  2. RCA Lyra X2400 flash card reader replacement, Screen: stap 2, afbeelding 1 van 2 RCA Lyra X2400 flash card reader replacement, Screen: stap 2, afbeelding 2 van 2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  3. RCA Lyra X2400 flash card reader replacement: stap 3, afbeelding 1 van 2 RCA Lyra X2400 flash card reader replacement: stap 3, afbeelding 2 van 2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  4. RCA Lyra X2400 flash card reader replacement: stap 4, afbeelding 1 van 3 RCA Lyra X2400 flash card reader replacement: stap 4, afbeelding 2 van 3 RCA Lyra X2400 flash card reader replacement: stap 4, afbeelding 3 van 3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. RCA Lyra X2400 flash card reader replacement, Motherboard: stap 5, afbeelding 1 van 2 RCA Lyra X2400 flash card reader replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  6. RCA Lyra X2400 flash card reader replacement, Compact Flash Card: stap 6, afbeelding 1 van 2 RCA Lyra X2400 flash card reader replacement, Compact Flash Card: stap 6, afbeelding 2 van 2
    • Locate the compact flash card slot on the logic board. For assistance on locating this component look at the picture to the left.
    • Use soldering/desoldering tools to remove the compact flash card.
    • Replace compact flash card and use soldering tools to complete the replacement.
Conclusie
Joseph Goodwin
1 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-3, Regan Spring 2013 Lid van Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 237
