Ga door naar hoofdinhoud
RCA Lyra X2400 USB port replacement
Wat je nodig hebt
  1. RCA Lyra X2400 USB port replacement, Screen: stap 1, afbeelding 1 van 2 RCA Lyra X2400 USB port replacement, Screen: stap 1, afbeelding 2 van 2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  2. RCA Lyra X2400 USB port replacement: stap 2, afbeelding 1 van 2 RCA Lyra X2400 USB port replacement: stap 2, afbeelding 2 van 2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  3. RCA Lyra X2400 USB port replacement: stap 3, afbeelding 1 van 3 RCA Lyra X2400 USB port replacement: stap 3, afbeelding 2 van 3 RCA Lyra X2400 USB port replacement: stap 3, afbeelding 3 van 3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  4. RCA Lyra X2400 USB port replacement, Motherboard: stap 4, afbeelding 1 van 2 RCA Lyra X2400 USB port replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  5. RCA Lyra X2400 USB port replacement, USB in/out: stap 5, afbeelding 1 van 2 RCA Lyra X2400 USB port replacement, USB in/out: stap 5, afbeelding 2 van 2
    • Locate the USB in/out component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
    • Start using solder/desolder tools to remove the USB in/out.
    • Once removed replace it with the new working USB in/out.
    • Use the soldering tools to reattach the component back to the main logic board.
Conclusie
Joseph Goodwin
1 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-3, Regan Spring 2013 Lid van Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 12
Altijd: 222
