Wat je nodig hebt
Remove the two Phillips screws from the silver cover at the top of the Lyra.
Slowly wiggle the silver cover while pulling it away from the device.
Open the case of the Lyra.
Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
Locate the audio jack on the Lyra X2400. If you have difficulty locating this component look at the picture to the left.
Start using the solder/desolder tools to remove this component.
Once removed replace the old audio jack with a new audio jack.
Use soldering tools to reattach this component back to the main logic board.
