Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the six 7.9mm Phillips #0 screws on the back and bottom.
Remove the one 3.8mm Phillips #0 screw on the bottom.
Remove the two 7.5mm Phillips #0 screws on the back and bottom.
Remove 5.8mm Phillips #1 screw from the side button panel.
Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
Pry along the seam on the top side near the buttons with a spudger.
Pull the left panel away from the rest of the camcorder.
Unplug the red speaker cable located at the rear of the device.
Unplug the red cable connecting the speaker to the motherboard.
Locate the speaker on the removed panel. Find the groove on the top left side of the speaker.
Pry the plastic up with a spudger until the glue breaks and the speaker is detached.
Break the plastic pieces holding the cable to the panel.
Glue the new speaker to the panel.
Plug the cable back into the motherboard.
