Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Lift the metal flap and slide the viewfinder off to the right.
Unscrew the 7.0mm ph#0 screw on the underside where the cable connects.
Lift the plastic where the cable is connected to the viewfinder.
Disconnect the cable inside by pulling it apart.
Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly.
Lift the viewfinder plastic assembly up.
Lift the microphone circuit board straight up.
Unclip the cable connected to the circuit board.
Turn the microphone circuit board over.
Unscrew the two Ph#0 screws holding the plastic housing on the circuit board.
Desolder the metal protective housing using a soldering iron.
Desolder the microphone and replace it.
Één andere persoon heeft deze handleiding voltooid.
