Ga door naar hoofdinhoud
RCA CC310 Main Motherboard Replacement
Wat je nodig hebt
  1. RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: stap 1, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: stap 1, afbeelding 2 van 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
    Vraag FixBot
    Voeg opmerking toe
  2. RCA CC310 Main Motherboard Replacement: stap 2, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
    Vraag FixBot
    Voeg opmerking toe
  3. RCA CC310 Main Motherboard Replacement: stap 3, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Pry along the seam on the top side near the buttons with a spudger.
    Vraag FixBot
    Voeg opmerking toe
  4. RCA CC310 Main Motherboard Replacement: stap 4, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
    Vraag FixBot
    Voeg opmerking toe
  5. RCA CC310 Main Motherboard Replacement, Main Motherboard: stap 5, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement, Main Motherboard: stap 5, afbeelding 2 van 2
    • Pull back the plastic tabs along the edges of the motherboard.
    • Disconnect all the cables along the left side of the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. RCA CC310 Main Motherboard Replacement: stap 6, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Disconnect all cables along the bottom of the motherboard.
    • Pull the motherboard away from the camcorder.
    Vraag FixBot
    Voeg opmerking toe
  7. RCA CC310 Main Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Oliver Adams
629 Reputatie
6 handleidingen geschreven
Cal Poly, Team 5-20, Amido Winter 2011 Lid van Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 51
Altijd: 3,346
