Ga door naar hoofdinhoud
RCA CC310 Main Motherboard Replacement
Wat je nodig hebt
  1. RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: stap 1, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: stap 1, afbeelding 2 van 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Main Motherboard Replacement: stap 2, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Main Motherboard Replacement: stap 3, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Main Motherboard Replacement: stap 4, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Main Motherboard Replacement, Main Motherboard: stap 5, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement, Main Motherboard: stap 5, afbeelding 2 van 2
    • Pull back the plastic tabs along the edges of the motherboard.
    • Disconnect all the cables along the left side of the motherboard.
  6. RCA CC310 Main Motherboard Replacement: stap 6, afbeelding 1 van 2 RCA CC310 Main Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Disconnect all cables along the bottom of the motherboard.
    • Pull the motherboard away from the camcorder.
  7. RCA CC310 Main Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Oliver Adams
629 Reputatie
6 handleidingen geschreven
Cal Poly, Team 5-20, Amido Winter 2011 Lid van Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 2,715
