Ga door naar hoofdinhoud
RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement
Wat je nodig hebt
  1. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: stap 1, afbeelding 1 van 3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: stap 1, afbeelding 2 van 3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: stap 1, afbeelding 3 van 3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 2, afbeelding 1 van 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 4, afbeelding 1 van 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 8, afbeelding 1 van 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 9, afbeelding 1 van 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
  10. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Antenna: stap 10, afbeelding 1 van 1
    • Identify the grey wire on the right side of the device.
  11. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Remove the orange ribbon cable over the wire.
  12. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Remove the antenna using a soldering iron.
  13. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Motherboard: stap 13, afbeelding 1 van 1
    • Remove the blue and black wire from the top of the motherboard.
  14. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Remove the screws from the motherboard.
  15. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Remove the motherboard.
Conclusie
Marcus Elysee
97 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 Lid van UMass Dartmouth, Team S1-G8, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G8
3 Leden
4 handleidingen geschreven
Één opmerking
Where can I buy this motherboard?
waymond everett - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 34
Altijd: 1,337
