Ga door naar hoofdinhoud
Quiksilver The Fifty50 Circuit Board Replacement
Wat je nodig hebt
  1. Quiksilver The Fifty50 Circuit Board Replacement, Strap: stap 1, afbeelding 1 van 2 Quiksilver The Fifty50 Circuit Board Replacement, Strap: stap 1, afbeelding 2 van 2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Circuit Board Replacement: stap 2, afbeelding 1 van 2 Quiksilver The Fifty50 Circuit Board Replacement: stap 2, afbeelding 2 van 2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Circuit Board Replacement, Back Panel: stap 3, afbeelding 1 van 2 Quiksilver The Fifty50 Circuit Board Replacement, Back Panel: stap 3, afbeelding 2 van 2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Circuit Board Replacement: stap 4, afbeelding 1 van 1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
  5. Quiksilver The Fifty50 Circuit Board Replacement, Analog Battery: stap 5, afbeelding 1 van 2 Quiksilver The Fifty50 Circuit Board Replacement, Analog Battery: stap 5, afbeelding 2 van 2
    • Carefully lift the white plastic circular out of the watch.
  6. Quiksilver The Fifty50 Circuit Board Replacement: stap 6, afbeelding 1 van 3 Quiksilver The Fifty50 Circuit Board Replacement: stap 6, afbeelding 2 van 3 Quiksilver The Fifty50 Circuit Board Replacement: stap 6, afbeelding 3 van 3
    • Remove the four 1.1 mm screws located on the metallic holder using the Phillips #00 screwdriver.
  7. Quiksilver The Fifty50 Circuit Board Replacement: stap 7, afbeelding 1 van 3 Quiksilver The Fifty50 Circuit Board Replacement: stap 7, afbeelding 2 van 3 Quiksilver The Fifty50 Circuit Board Replacement: stap 7, afbeelding 3 van 3
    • Remove the large circular Analog battery.
  8. Quiksilver The Fifty50 Circuit Board Replacement, Circuit Board: stap 8, afbeelding 1 van 2 Quiksilver The Fifty50 Circuit Board Replacement, Circuit Board: stap 8, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver, remove the two 1 mm screws holding the circuit board to the device.
  9. Quiksilver The Fifty50 Circuit Board Replacement: stap 9, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the green circular chip using a pair of tweezers.
Conclusie
Sue Giske
622 Reputatie
5 handleidingen geschreven
UW Tacoma, Team S1-G4, Liner Summer 2019 Lid van UW Tacoma, Team S1-G4, Liner Summer 2019
UWT-LINER-SU19S1G4
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 220
