Ga door naar hoofdinhoud
Quiksilver The Fifty50 Back Panel Replacement
Wat je nodig hebt
  1. Quiksilver The Fifty50 Back Panel Replacement, Strap: stap 1, afbeelding 1 van 2 Quiksilver The Fifty50 Back Panel Replacement, Strap: stap 1, afbeelding 2 van 2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Back Panel Replacement: stap 2, afbeelding 1 van 2 Quiksilver The Fifty50 Back Panel Replacement: stap 2, afbeelding 2 van 2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Back Panel Replacement, Back Panel: stap 3, afbeelding 1 van 2 Quiksilver The Fifty50 Back Panel Replacement, Back Panel: stap 3, afbeelding 2 van 2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Back Panel Replacement: stap 4, afbeelding 1 van 1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
Conclusie
Sue Giske
622 Reputatie
5 handleidingen geschreven
UW Tacoma, Team S1-G4, Liner Summer 2019 Lid van UW Tacoma, Team S1-G4, Liner Summer 2019
UWT-LINER-SU19S1G4
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 194
