Inleiding
A missing or broken pull on a zipper can make life difficult when you try to open and close your Patagonia jacket. This guide will show you a quick-fix method you can use in the field or as an interim solution until you can replace your slider. Don't have a zipper pull? A loop of very thin cord or string will not only work, but make MacGuyver proud.
For replacement parts or further assistance, contact Patagonia Customer Service.
Gereedschap
Geen gereedschap nodig.
Onderdelen
  1. Grab your zipper pull. Thread the cord of the zipper pull through the hole on the slider where the pull used to be. Thread the cord of the zipper pull through the hole on the slider where the pull used to be.
    • Grab your zipper pull.
    • Thread the cord of the zipper pull through the hole on the slider where the pull used to be.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  3. Make a loop with the cord that has passed through the hole. Feed the rubber end through the loop.
    • Make a loop with the cord that has passed through the hole.
    • Feed the rubber end through the loop.
  4. Pull the rubber part through the loop, then pull it tight. Pull the rubber part through the loop, then pull it tight. Pull the rubber part through the loop, then pull it tight.
    • Pull the rubber part through the loop, then pull it tight.
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
80.693 Reputatie
132 handleidingen geschreven
iFixit Lid van iFixit
Community
109 Leden
7.761 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 5
Afgelopen 7 Dagen: 63
Afgelopen 30 Dagen: 186
Altijd: 7,089
