Ga door naar hoofdinhoud
Quantum Axis A23 Camera Replacement
Wat je nodig hebt
  1. Quantum Axis A23 Camera Replacement, Removing the Case: stap 1, afbeelding 1 van 1
    • Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
    • Be careful not to crack front screen in the process.
  2. Quantum Axis A23 Camera Replacement, Detaching the Camera from the Motherboard: stap 2, afbeelding 1 van 1
    • Use small needle nose pliers to carefully remove the yellow ribbon attached to the motherboard.
  3. Quantum Axis A23 Camera Replacement, Detaching the Camera from the Back of the Screen: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to remove the black tape holding the camera down.
  4. Quantum Axis A23 Camera Replacement, Attaching New Ribbon to Motherboard Slot: stap 4, afbeelding 1 van 1
    • Slot the new dual camera ribbon into the motherboard.
  5. Quantum Axis A23 Camera Replacement, Attach New Dual Cameras to Screen: stap 5, afbeelding 1 van 1
    • Attach dual cameras to the back of the screen with the black tape. Align the cameras with the designated hole in the case.
    • Fold over the camera piece so the camera are on top of each other with lenses facing out and the top as the rear.
Conclusie
Snap the rear case back on (carefully aligning the back camera with the camera hole on the case) to finish this repair.
Randy Janz
101 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-5, Tanski Winter 2015 Lid van USF Tampa, Team 1-5, Tanski Winter 2015
USFT-TANSKI-W15S1G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 213
