Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
Once the device is open, remove the tape from the the battery.
Carefully pry up the battery by wedging the plastic opening tool under the battery. It is glued to the screen so it will be a delicate removal process.
Once the battery is removed, take wire cutters to the two wires attaching the battery to the motherboard and cut the red and black wires in the middle. Then, strip the both the red and black wires halfway with the wire stripper/cutter tool.
Take the new battery and strip both the red and black wires in the middle with wire stripper/cutter tool.
Take the red wire from the battery and the red wire from your device's motherboard and twist the two ends together then wrap in electrical tape. Repeat this step for the black wires.
