Ga door naar hoofdinhoud
Qualcomm QCP-2760 Motherboard Replacement
Wat je nodig hebt
  1. Qualcomm QCP-2760 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Qualcomm QCP-2760 Motherboard Replacement, Rear Backing: stap 2, afbeelding 1 van 2 Qualcomm QCP-2760 Motherboard Replacement, Rear Backing: stap 2, afbeelding 2 van 2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
  3. Qualcomm QCP-2760 Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Locate the four metal clips holding the motherboard onto the phone.
    • Pull the clips away from the motherboard while lifting the motherboard out of the case.
    • The motherboard is attached to the case by a fragile cable, do not apply any stress to the cable.
  4. Qualcomm QCP-2760 Motherboard Replacement: stap 4, afbeelding 1 van 2 Qualcomm QCP-2760 Motherboard Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Place the motherboard down so that the screen is facing up.
    • Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
    • Locate, but do not disconnect, the four screen clips.
  5. Qualcomm QCP-2760 Motherboard Replacement: stap 5, afbeelding 1 van 2 Qualcomm QCP-2760 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Flip the motherboard over so that the screen is facing down.
    • Again, be careful not to put stress on the speaker cable.
Conclusie
Graham
107 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-4, Buehl Fall 2014 Lid van Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 289
