Ga door naar hoofdinhoud
Qanba Crystal Joystick and Buttons Replacement
Wat je nodig hebt
  1. Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: stap 1, afbeelding 1 van 3 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: stap 1, afbeelding 2 van 3 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: stap 1, afbeelding 3 van 3
    • Use the Phillips #1 screwdriver to remove the eight 20 mm screws.
    • Remove the metal plate to gain access to the internals of the device.
  2. Qanba Crystal Joystick and Buttons Replacement: stap 2, afbeelding 1 van 3 Qanba Crystal Joystick and Buttons Replacement: stap 2, afbeelding 2 van 3 Qanba Crystal Joystick and Buttons Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Taking a picture or marking cables with masking tape is advised as it will help with the reassembly process.
    • Each button has three cables, unplug these from each one.
    • The joystick has two cables, unplug both of these.
    • The use of ESD safe tweezers may assist with unplugging the cables.
  3. Qanba Crystal Joystick and Buttons Replacement: stap 3, afbeelding 1 van 3 Qanba Crystal Joystick and Buttons Replacement: stap 3, afbeelding 2 van 3 Qanba Crystal Joystick and Buttons Replacement: stap 3, afbeelding 3 van 3
    • Use the Phillips #1 screwdriver to remove the four 10 mm screws.
    • Use a flathead screwdriver to hold the screw in place.
    • Twist off the ball top of the joystick while holding the screw in place with a screwdriver.
    • Remove the joystick and all of it's components.
  4. Qanba Crystal Joystick and Buttons Replacement: stap 4, afbeelding 1 van 1
    • Press in the tabs on the top and bottom of the buttons to remove them.
    • The outline of the buttons are sharp, do exercise caution with the removal of the buttons.
  5. Qanba Crystal Joystick and Buttons Replacement: stap 5, afbeelding 1 van 3 Qanba Crystal Joystick and Buttons Replacement: stap 5, afbeelding 2 van 3 Qanba Crystal Joystick and Buttons Replacement: stap 5, afbeelding 3 van 3
    • Flip the controller over.
    • Peel the six shiny stickers and their epoxy glue off of the controller.
    • Remove the six newly revealed Phillips screws.
    • Remove the acrylic panel.
Conclusie
Kevin Vu
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 113
Altijd: 2,038
