Ga door naar hoofdinhoud
QFX IT-437 Motherboard Replacement
Wat je nodig hebt
  1. QFX IT-437 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Motherboard Replacement: stap 2, afbeelding 1 van 2 QFX IT-437 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • In order to unseat the motherboard, use the Phillips PH00 screw driver bit to remove the three 1.2mm x 3mm screws.
  4. QFX IT-437 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Once the motherboard is loose, remove the tape above the SD card slot using an iFixit opening pick.
    • Be careful not to rip or damage the tape or else new tape will have to be used for the new motherboard.
  5. QFX IT-437 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Use the spudger to remove the ribbon.
    • Avoid using too much force here or else the ribbon can be ripped.
  6. QFX IT-437 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use the spudger in the top corner of the tablet and lift the camera up.
  7. QFX IT-437 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Lift the tape over the wires that are holding them to the tablet insulation.
  8. QFX IT-437 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Pull out the motherboard and set it aside.
    • The wires must be soldered back on to the motherboard.
Conclusie
Douglas
482 Reputatie
4 handleidingen geschreven
Pasco Hernando, Team 5-2, Prince Winter 2015 Lid van Pasco Hernando, Team 5-2, Prince Winter 2015
PHSC-PRINCE-W15S5G2
6 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 227
