Ga door naar hoofdinhoud
QFX IT-437 Battery Replacement
Wat je nodig hebt
  1. QFX IT-437 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Battery Replacement: stap 2, afbeelding 1 van 2 QFX IT-437 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the tape connecting the battery to the motherboard.
    • Save the tape in good condition for the replacement so the wires do not get stuck in the case.
  4. QFX IT-437 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the black tape attaching the wires to the battery.
  5. QFX IT-437 Battery Replacement: stap 5, afbeelding 1 van 1
    • Use the plastic opening pick in order to remove the battery from the tablet, and set it aside for the replacement.
    • The removed wires will have to be soldered back on to the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Douglas
482 Reputatie
4 handleidingen geschreven
Pasco Hernando, Team 5-2, Prince Winter 2015 Lid van Pasco Hernando, Team 5-2, Prince Winter 2015
PHSC-PRINCE-W15S5G2
6 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 378
