Ga door naar hoofdinhoud
Puritan Bennett 540 Battery Replacement
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
Wat je nodig hebt
  1. Puritan Bennett 540 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the ventilator on a work table.
  2. Puritan Bennett 540 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the three screws (item one) securing the battery cover with a Torx T10 screwdriver. These screws consist of two Torx head screws on the back panel and one Torx head screw on the bottom of the ventilator, as shown (depends on the version of the device).
  3. Puritan Bennett 540 Battery Replacement: stap 3, afbeelding 1 van 1
    • Slide the battery cover ( item 2) off by pulling it towards the back of the ventilator.
  4. Puritan Bennett 540 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the old battery ( item 3) from the battery cover.
  5. Puritan Bennett 540 Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the replacement battery from its package and install it into the battery cover. Make sure you remove the pull tabs (if they are present) from the battery’s contacts.
  6. Puritan Bennett 540 Battery Replacement: stap 6, afbeelding 1 van 1
    • Place the battery cover containing the replacement battery back onto its slide rails within the ventilator.
    • Note: Push on the battery cover from the rear towards the front when tightening screws to make sure nothing breaks.
Conclusie
To reassemble your device, follow these instructions in reverse order
Nina Aliamus
133 Reputatie
1 Handleiding geschreven
Cal Poly, Team S7-G7, Paton Spring 2020 Lid van Cal Poly, Team S7-G7, Paton Spring 2020
CPSU-PATON-S20S7G7
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 139
