Ga door naar hoofdinhoud
Protocol Slipstream EVO Propeller blades Replacement
Wat je nodig hebt
  1. Protocol Slipstream EVO Propeller blades Replacement, Propeller blades: stap 1, afbeelding 1 van 1
    • With the drone flat on the ground identify which propeller you will be replacing.
  2. Protocol Slipstream EVO Propeller blades Replacement: stap 2, afbeelding 1 van 2 Protocol Slipstream EVO Propeller blades Replacement: stap 2, afbeelding 2 van 2
    • Using two fingers, place them on each side of the propellor near the middle.
    • Pull straight up with force. The propellor will feel as if it will not come off but do not be scared to use some muscle.
    • Warning: Pulling at an angle will result in bending the motor's needle.
  3. Protocol Slipstream EVO Propeller blades Replacement: stap 3, afbeelding 1 van 3 Protocol Slipstream EVO Propeller blades Replacement: stap 3, afbeelding 2 van 3 Protocol Slipstream EVO Propeller blades Replacement: stap 3, afbeelding 3 van 3
    • Checking the underside of the propeller there will be a letter which will correspond with each side of the drone
    • On the corner of the drone where the blade mounts onto the motor you will see which blade you should be using.
    • Warning: Failure to match the propeller blade to the right motor may result in the drone not flying.
    • Lining up the propeller blade with the needle, push down until the propeller is flushed.
Conclusie
Michael Dang
301 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S3-G3, Liner Spring 2017 Lid van UW Tacoma, Team S3-G3, Liner Spring 2017
UWT-LINER-S17S3G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 535
