Ga door naar hoofdinhoud
Protocol Slipstream EVO Propeller Guards Replacement
Wat je nodig hebt
  1. Protocol Slipstream EVO Propeller Guards Replacement, Propeller Guards: stap 1, afbeelding 1 van 1
    • With the drone flat on the ground, identify which propeller guard you will be replacing.
    • The front of the drone is where there are no wires exposed.
  2. Protocol Slipstream EVO Propeller Guards Replacement: stap 2, afbeelding 1 van 2 Protocol Slipstream EVO Propeller Guards Replacement: stap 2, afbeelding 2 van 2
    • With the plastic opening tool, pry the side of the guard closest to the front or the back of the drone depending on where you decided to start from.
    • After prying off one side of the guard, pushing down on the same side will release the other side of the clip.
    • Repeat this step for the following side as needed.
  3. Protocol Slipstream EVO Propeller Guards Replacement: stap 3, afbeelding 1 van 2 Protocol Slipstream EVO Propeller Guards Replacement: stap 3, afbeelding 2 van 2
    • With the replacement guard line up the clips and push the clips into place.
    • After the guard has been attached to the drone, pinch the clips as you push the guards to ensure they are secured.
Conclusie
Michael Dang
301 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S3-G3, Liner Spring 2017 Lid van UW Tacoma, Team S3-G3, Liner Spring 2017
UWT-LINER-S17S3G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 171
